6. Toyota Prius hybride rechargeable (2023) - La fiche technique
Essai vidéo – Toyota Prius (2023) : méconnaissable
MOTEUR THERMIQUE
PRIUS HYBRIDE RECHARGEABLE
TYPE
4 CYLINDRES EN LIGNE,
2.0 L HYBRID DYNAMIC FORCE
DISTRIBUTION
16 SOUPAPES DACT
ALIMENTATION
INJECTION D’ESSENCE
CYLINDREE (CM3)
1 987
ALESAGE X COURSE (MM)
80,5 X 97,6
TAUX DE COMPRESSION (:1)
14,0
PUISSANCE MAXI (CH / KW @ TR/MN)
152 / 112 @ 6 000
COUPLE MOTEUR THERMIQUE SEUL (NM @ TR/MN)
190 @ 4 400-5 200
SYSTEME HYRBIDE RECHARGEABLE
BATTERIE HYBRIDE
LITHIUM-ION
CAPCITE DE LA BATTERIE (kWh)
13.6
TYPE DU MOTEUR AVANT
MOTEUR SYNCHRONE A AIMANT PERMANENT
PUISSANCE MAXI MOTEUR ELECTRIQUE (CH / KW )
163 / 120
COUPLE MAXI MOTEUR ELECTRIQUE (NM)
208
PUISSANCE CUMULEE (CH / KW)
223 / 164
PERFORMANCES
VITESSE MAXI (KM/H)
177
ACC. 0-100 KM/H (SEC)
6,8
CONSOMMATION D’ENERGIE
17”
19”
CYCLE MIXTE WLTP (L/100 KM)
0.5
0.7
CYCLE MIXTE WLTP (Wh/KM)
114
125
CO2 / KM WLTP (G)
11
16
HOMOLOGATION
EURO 6 AP
AUTONOMIE 100 % ELECTRIQUE (KM)
86
72
CAPACITE DU RESERVOIR (L)
40
CHASSIS
17”
19”
SUSPENSION AVANT
MACPHERSON
SUSPENSION ARRIERE
DOUBLE TRIANGLE
DIRECTION
CREMAILLERE & PIGNON
NOMBRE DE TOURS DE VOLANT, BUTEE A BUTEE
2,84
2,76
DIAMETRE DE BRAQUAGE ENTRE TROTTOIRS / ENTRE MURS (M)
5,3 / 5,6
5,4 / 5,75
DIMENSIONS EXTERIEURES (MM)
17”
19”
LONGUEUR
4 599
LARGEUR
1 782
HAUTEUR
1 420
1 430
VOIE AVANT
1 563
VOIE ARRIERE
1 579
1 580
EMPATTEMENT
2 750
PORTE-A-FAUX AVANT
974
PORTE-A-FAUX ARRIERE
875
GARDE AU SOL
137
144
Photos (43)
Essais Moyenne Berline
