6. Essai - Aprilia Dorsoduro 1200 2012: Fiche technique
Essai - Aprilia Dorsoduro 1200 2012: Danse sur un volcan !
Prix: 10 999,00 € en version ABS et 9 999,00 € en standard
Moteur : Aprilia four-stroke longitudinal 90° V-twin, liquid cooled, double overhead camshafts with mixed gear/chain timing system and four valves per cylinder.
Carburant : Unleaded petrol
Alésage course : 106 x 67.8
Cylindrée : 1197 cc
Rapport de compression : 12.0 ± 0.5: 1
Puissance maximale à l'arbre: 130 hp (96 kW) at 8,700 rpm
Couple maximum à l'arbre : 11.7 Kgm (115 Nm) at 7,200 rpm
Alimentation : Integrated engine management system. Injection system with triple map Ride by Wire throttle management: Sport (S), Touring (T), Rain (R)
Allumage : Digital electronic ignition integrated with injection system.
Démarrage : Electric
Echappement : 100% stainless steel 2-into-2 exhaust system with dual catalytic converters and oxygen sensor.
Générateur : 450 W/6000 rpm
Lubrification : Wet sump
Boîte de vitesses : 6 speeds, drive ratio: 14/36, 17/32, 20/30, 22/28, 23/26, 24/25
Embrayage : Multiplate wet clutch, hydraulically operated.
Transmission primaire : Straight cut gears, drive ratio: 40/69
Transmission secondaire : Chain. Drive ratio: 16/40
Cadre : Modular tubular steel frame fastened to aluminium side plates by high strength bolts. Removable rear aluminium subframe.
Suspension avant : Æ 43 mm Sachs upside-down front fork with fully adjustable compression and rebound damping and spring preload. Wheel travel 160 mm.
Suspension arrière : Aluminium alloy swingarm Piggy-back design Sachs hydraulic shock absorber with fully adjustable compression and rebound damping and spring preload. Wheel travel 155 mm.
Freins : Front: Dual Æ 320 mm stainless steel floating discs. Brembo four-piston radial callipers. Metal braided brake hose. Rear: Æ 240 mm stainless steel disc. Single piston Brembo calliper. Metal braided brake hose. Two channel Continental ABS with Aprilia Traction Control (ATC) (specific version)
Jantes : Aluminium alloy Front: 3.50 X 17" Rear: 6.00 x 17"
Pneumatiques : Radial tubeless tyres; front: 120/70 ZR 17; rear: 180/55 ZR 17
Dimensions: Max. length 2248 mm Max. width 925 mm (at outer edges of hand guards) Max. height 1205 mm (at instrument panel brow) Saddle height 870 mm Wheelbase 1528 mm Trail 118 mm Steering angle 27.3°
Réservoir : 15 litres (including 3.5 litre reserve)
Photos (40)
Actualité Aprilia
